98 355 : Wheres the splitter?
jcs707
Anyone know where the factory hid the CATV splitter? Just purchased a 98 355 and want to upgrade the AV system - sure need to find this splitter.
/Clint
Clint,
I too just purchased a 98 355 and the splinter is located in the aft stateroom behind the fwd facing closet doors.
Mine is set up like this: An antenna is located on the bridge with a cable leading to the aforementioned closet. An antenna amplifier boost the signal then is split by an A/B switch. Depending on the position of the A/B switch the signal goes to the saloon TV or the aft stateroom TV. The aft stateroom TV was removed by the PO.
Hope this helps.
Tim
OOPS, just noticed you mentioned CATV splitter. Can't help you there.
Tim
