Originally posted by nph
I won't comment on the pros aznd cons of flushing your A/C, but I will tell you an easy way to setup to do this.
In the water inlet line past your seacock, put a tee fitting, run a hose to a ball valve that is easily reached, mine is under the gunnel. From there go to a water inlet fitting, such as you would use for a dockside water inlet.
It is real easy to flush your ac lines, you can either close or leave the seacock open, hook up a garden hose to the inlet, open the ball valve, and your all set.
I do this all the time, not to flush the system but to purge it out. From time to time I lose prime on my A/C pump. The previos owner installed this so he did not have to go into the blidge to purge the line. The other perk to this is if the inlet becomes clogged, it is easy to clear out.
