A/C Installation?
rnbenton
Need some technical advice and direction, please. I have a 7000 btu A/C I want ti install in my Carver Voyager 28. It looks to me that the best place to put it is under the aft dinette bench (lots of space, nothing else in it) Now for the questions: 1) I don't really want to drill another hole in the hull so, will it work if I hook the A/C water pump to the through hull fitting for the head? The head is a vacu-flush raw water source so It looks to me like I can simply hook my A/C pump to that since the head is not used all that much. Will it work? 2) Regardless, the A/C unit will be about 3 ft from the water source through hull fitting. What size pump do I need to use?
You guys are terrific and I look forward to your sage advice. :)
Do it right and install another thru hull and strainer. It can be done with the boat in the water.
As to the size of the pump, use a March Series 3 pump mod. # LC-3CP-MD .
Oh yeah, one other thing I forgot to mention, I am planning to replace my raw water vacu-flush with a fresh water electric macerator flush head this Summer. it will be a few months before I do this but that is the plan.
Originally posted by rnbenton
What Bill said do them both at the same time. Remember that A/C pumps are not self priming and need to be below the water line and not have high spots in the line.
Well, in that case, you could T off the head thru hull in the short term I guess. Just don't get lazy and let it go. :-)
Question. How does one Drill a new tru hull with the boat in the water or did I miss something ? Im picturing this gyser the hole saw goes tru ??
You can tee off your head thru-hull and run the 7K BTU AC. I have done it and it works just fine. For simplicity about waterlines just mount the AC pump online or below the thru-hull. I'm currently using a 3/4 inch thru-hull and a bronze tee to run the head and a 9K BTU OceanBreeze AC. No problems.
Depending on the type of head and the plumbing, the AC MIGHT suck air back from the head. However the only way to know for sure is to try it. In your case I would.
The short version is, very carefully.
The long version involves a bucket, a diver and some preplanning.
Works like a charm.
<"...vacu-flush raw water source...">
HUH. Never heard of such a thing.
Anyhow, drill the hole and do it right the first time. Does the head have a scooped intake? if not, you run the risk of losing prime underway. Are you sure you can constant necessary uphill run from the raw water intake to the pump to the AC from your desired "T" location?
Dometic informed me a few years ago there are some self priming pumps available but they are expensive and noisy. I kept losing prime and was considering one. The prime loss was due to a poor install. They fixed that and I was a very happy boater from that point.
Good Luck.
LOL Thanx Bill.... I would need a REALLY big bucket sir !
When we bought our boat, the original owners changed the head to a self contained one
and used the thru hull for the head to run the a/c. When I got on plane, the a/c went
down on high head pressure. It didn't have a scoop and the water passing over the
inlet caused a suction across the inlet. I have since installed a manual head and hooked
it up to the intake it was meant for and added a scoop intake for the a/c.
No more a/c problems and no more manual dumping head.
If you are going to spend the money to install an a/c, why not hook it up right and not
have to worry about it.
Boating is not cheap. While it is out, change the anodes and clean the bottom.
your a/c mfg will have a manual for your unit. in the installation instructions will be the specification of how many gallons per minute you need to run thru the unit. size your pump just slightly above that specification to allow for frictional loss while operating. there is also an industry standard on the feet per minute of water travel thru the system to minimize the growth of sea life in the lines. sorry i don't recall that spec, but if you have a marine a/c contractor in your area its worth a call to them to find this out. my point is that you need to size your supply and return water lines to maintane this water speed to avoid problems with growth. to large a line creates less backpressure but that comes at the expense of slow water speed which is counter productive in this application.
Sure, you can drill a hole thru the bottom and get away with it, but why would you want to. Too much stress! Regarding pumps, don't waste your money on a Cal pump. Get the appropriate sized March pump.
Sea life such as barnacles and such only grow where there is light. Do not use clear lines.
There should not be any issues with stuff growing in the hoses.
You might get some scale build up in the heat exchanger if you don't have enough water to
cool the freon within the exchanger.
Like I said, get a March Series 3 pump mod. # LC-3CP-MD.
And don't mount it below the thru hull. The water should flow up a bit to the strainer and then up a bit to the pump. That way any air will flow through the strainer and the pump. Just be sure the pump is below the water line so is primes OK.
Almost all aircon water hoses are 5/8 in and out of the coils. (At least until you get up to big chillers for chilled water systems.) And water speed will not stop growth that I've ever seen. In fact the stuff that grows likes water movement of any kind cause it brings in food and oxygen. As rduhon noted, lack of light helps a lot in that area.
I have had a thin scum in my exchanger but nothing in my hoses. I changed my hoses
after I bought the boat. The original hoses were in there 25 years.
I boat in salt water. But the boat was in fresh water for 18 years before salt water.
I installed A/C in a previous boat, a 30' Rinker. I faced the exact same problem and after discussing with several people decided to switch the head to draw from the freshwater tank (used a backflow preventer) and used the bottom thru-hull for the A/C draw. It worked fine for the A/C but it took a bit more effort to pump the manual head for some reason. One of the benefits was much less problem with head vent odors due to using freshwater vs. the river water. The type of thru-hull pick-up was not an issue for me as we did not have a generator so could not use the A/C away from the dock anyway.
What's the difference between the pump you recommend and the March AC-3CP-MD? Will either one work or is the LC better?
