- Jun 28, 2007
- 27052
- 263
With all of your help I installed an a/c unit in a '89 255xl last winter. I had to adjust some vent positions to get everything to work right but now it is cooling the boat just fine. If you don't recall, I installed a 16,500 btu reverse cycle unit from mermaid air. At the time everyone told me that this unit was WAY too big but I got a heck of a deal on her from a friend who had it sitting in his garage. Last weekend I opened up the cabinet that the unit is located in; I just wanted to make sure everything looked good and I didn't have any wires chaffing. I noticed that the condensation tank was "sweating" pretty bad and the wood closet I had built around the unit was damp. The unit is draining fine, but the cold water sitting in the catch basin is causing the unit to sweat. Humidity in Ohio has been pretty high...approx. 80%+ most days. How can I prevent this or what's wrong, this doesn't seem normal to me? Normally I keep the boat at 68 deg. Fahrenheit and the unit is only on for the weekend, so it has alot of humidity to remove Friday night when I turn it on. There is always a small amount left in the condensation pan that won't drain and I'm sure some of this splashes out when we are underway but why am I seeing beads of water collecting on the outside of the pan and running down to the floor? Any help would be appreciated.
Chris
Chris
