As for your speed, a few things to keep in mind.
1) Use the GPS for speed not the speedo if you have one.
2) The Hudson has an approx. 2MPH (1.6k) current at max flood/ebb so you can have a roughly 4MPH differential which you seem to be saying here.
Assume 50MPH with no current then you are +- 2 with/without current or 52/48. Just something to keep in mind. A lot of people tend to forget this fact. Also as the season goes on we as boat owners tend to load up the boat with extra stuff. And you will def. see slower speeds this time of year as opposed to early in season due to temperature changes. An engine can make more power at 70 degrees than it can at 90 degrees.
The more I think about this I believe others are correct in that you probably have a flaky sensor and the boat is running fine...
