Ablative Paint Question
gardnersf
Teh boat I am buying as Ablative bottom paint. It was painted last spring and has not been in the water since. The paint is sound, no chips or light spots.
Does the boat need to be painted again before dropping in. I am in NE and the boat spends about 5 montsh in water in moderate fouling conditions.
My current boat has hard bottom paint, so I'm not sure.
Nope, just drop it in. Ablatives can be dry indefinitely.
Beautiful, It's going in Monday and I didn't want to take it out later or paint it before I closed on it. I have to paint mine as it is (trade deal)
Enjoy the new boat! I had my ablative paint job last me 5 years. It was in the water 365 days/yr, but I did pull it 3 times each summer to pressure wash the hull.
You need to find out exactly which ablative paint it is. Most ablatives are multi season and do not need to be splashed right away and can come out of the water in the fall and be relaunched in the spring. Some products need to be launched within 30 days of painting and can only come out of the water a short time. Petit Ultima and Interlux Micron are good paints and can go back in the water after staying on land for up to tow years I think.
Before the five years was up, I moved my boat to a lift in the slip. Ablative paint still worked fine. Mine was Interlux Micron.
Michael,
I don't know of any ablatives that have a "shelf life" when the boat is on the hard. Which ones are they???
Most new paints are multi season. Pettit Premium SSA is not multi season.
Scott,
Congrats on the new boat. I'll look for it in Potters. As for the paint, this is a question I've asked around about here locally. While the manufacturers like Interlux all say that you can resplash ablatives for multiple seasons before repaint, it seems like most folks I've talked to around here at least do a light sand and repaint. That is what I've done each of the past two years. But bottom painting and sanding is a nasty job and I would love to skip it once in awhile. I've just been paranoid about the local knowledge. Let us know how you make out.
Deal is not finalized yet, Sea Trial is on Friday, but I was trying to determine if I was going to have to pull it out to repaint later. I'm going to go with it as is. The surveyor seemed to think it woudl be fine. The paint was in new condition. and shoudl start to erode on use.
I just painted my current boat and drives over the weekend. It is a pain. I don't like working with the respirator on, but the fumes are obnoxious.
I live in NC, use ablative paint and my boat stays in the water 365 days a year. A diver comes monthly to clean the bottom and change zincs as needed. I only haul and paint my boat every two years.
a better answer is had by finding out exactly what brand of paint is on the bottom and check the mfg's website. you will want to know what brand is on there so when it's time to repaint you can use it again and not have to worry about delamination as some brands won't stick to another very well. could save you a real headache. :-)
