I have a 2004 34C Silverton with a Cruise Air AC with SMX controller. If I set the SMX controller for a temp, in the heat mode, it just continues to run. I am thinking a thermostat problem (Controller?).
This may also happen in the cool mode, but it is not hot enough here to test that.
Any ideas on where to start, look, or test?
This happened today, I set the controller for 73, back in the boat 20 minutes later, the boat was 83 degrees. Same thing happened last week, I thought it was a glitch, reason being is I booted the system down, set a temperature, and for the short period of time it seemed to work.
After today, I am sure I have a problem and it was not a glitch.
