I recently had to replace the AC water pump on my '89 Sundancer. It runs whenever the AC is on. A dock neighbor told me it should only run when the compressor is running, which makes sense. I checked the wiring diagram and it is connected as per the Cruisair manual. Is there a good place to connect this pump so it will only run when the compressor is running? How are yours set up?
