cornersoyo
- May 25, 2007
- 26442
- 5
I have a 16' Browning (tri-hull, heavy boat) with a mercury 850 (long shaft of course). I have a side mount bracket (20HP rated) where I have a 55# thrust trolling motor, which does move the boat but of course slowly. I want to replace this with a small HP gas motor. My 2 questions are: (1) Does it always follow suit that long-shaft main moter = long shaft kicker? Can this motor be a short shaft so long as it is able to reach low enough to use intake / circulate water? The bracket is set up that it is level with the transom when lowered, but of course the transom itself doesn't go as low on the sides as in the middle. (2) How would a 4HP or 6HP compare to a 55# trolling? Just want a little more movement, not a lot. Thank you for any thoughts to this. Cornelius R. Soyo
