When I am in my slip, but not on the boat, I turn the cabin A/C off. Ususlly crack open a hatch for a little ventilation (covered slip), and also open a few galley drawers to let the the trapped heat behind the refer escape. Has anyone else found anything helpful with cold retention in these small refrigerators ? Adding insulation is an issue because the opening to slide the refer unit in and out is the exact dimension of the refer box. And adding insulation after the install isn't practical. These things are catch 22. The hotter it gets, the more they run, the more. . . . .
