Adhesives Question
gcolton
Well-known member
I will be installing two sets of drawer units in my Pursuit. I am almost finished building them and am thinking about the adhesive I will use. Both units are totally self supporting units that will be glued and screwed to the fiberglass under a dinette seat and the other under a bunk. The face plate around the drawer is to fit essentially flat against the fiberglass.
I am considering both epoxy and 5200 as the adhesive. Because I have never worked with 5200 I do not know it's physical characteristics. Is the consistency thin enough that it can be spread thin so that no gap shows between the fiberglass and the wood? Would someone who has worked with 5200 tell me the characteristics?
If it is too thick I will use epoxy.
By the way, I am using Iroko wood, which is touted to be very similar to teak at 1/4 the price. I am going to use an oil finish. If it comes out near teak looking I will post pictures. In it's natural state it is quite teak looking.
G
G
I have found 5200 to be similar in thickness to say silicone. I don't recall it ever having any expansion issues.
Since you are using screws, have you considered something less 'permanent' such as 4200 or even silicone?
3M 5200 has the consistancy of silicon adhesive or toothpaste and is very sticky. Yes, it will fill gaps less than 1/4" just fine for your purpose. When cured, it retains a litle flexibility but is not as hard as epoxy.
Unless you really need the strength of 5200 for fastening, I'd use 4200 or another polyurethane sealant like Sikaflet 291LOT (my favorite). Cured 5200 is difficult to remove if you ever want to do a disassembly while the Sikaflex will allow rebuilding. The softer polyurethanes are easier to work with and clean up during use.
Thanks for the information.
If you are comparing 5200 to silicone then I will go with the epoxy. I want something that will be able to worked very flat between the two surfaces.
I am only going to screw if I feel like the adhisive is not holding sufficiently. In prep for this I will be flueing an oak strip all around the inside edge of the opening. I do not want screw heads showing if I do not have to. The wood is not think enough to use plugs to hide the screw heads. Just under 1/2 inch.
By the way, I found out that here Lowes sells the 5200, both regular and fast cure. They also have the Teak Oil, which I expected.
G
If you want a permanent, waterproof installation, use the epoxy. If you can get some clamps on it, you won't need any fasteners. Keep in mind, if you ever need to remove this drawer unit, you will have to cut the wood as the epoxy bond will be stronger than the wood itself. You can brush the epoxy on both surfaces and clamp it. Wipe up any drips before they cure. Acetone is the solvent for epoxy, but be careful about using it on the adjacent areas. You may want to put some blue painters tape on the surrounding area to keep things clean and neat.
If that wood has much oil in it, the Epoxy wont sink into the wood very far at all. Maybe not at all.
So engineer your project so the Epoxy has a good mechanical hold on the wood.
George,
From the description of what you intend to do, I would use a two part epoxy. Choose one that has a long open time, is relatively flexible and is low strength. Anytime you try to bond a permeable (wood) and impermeable (fiberglass) substrate with a one component product, your cure times are going to be greatly extended because the adhesive/sealant will form a skin around the bondline perimeter and keep the product from curing at it's normal rate.
The coefficient of expansion and contraction of the wood and fiberglass should be similar in nature and should not place undue stress on the bondline. The thinner the bondline, the less forgiving the adhesive is going to be if it is subjected to wide temperature swings. That's why you want a flexible adhesive.
The iroko is not oily like teak. However, if you want to be on the safe side, wipe the wood with acetone, prior to bonding. The acetone wipe will eliminate any surface contamination.
BobV1
Good idea on wiping the wood down first. Thanks.
G
I can get you some info on a teropolymer rubber caulk (available in 200+ standard colors) will expand up to 300% and will work on above the waterline applications. Pricing is cheaper than 5200 or 4200 for a standard size tube of caulk.
I would use West System epoxy to bond the wood together.
After re-reading your initial post, it sounds like you'll be bonding a trim ring around a fiberglass cutout and then installing a drawer. If this is the case, you'll have access to the rear of the fiberglass panel. You could drill a series of holes through the fiberglass and mount the trim from the rear. This would allow you to use either a one or two component adhesive. Since, the screws will be the primary fastening mechanism.
You could also go to www.itw-fastex.com and look at their double ended christmas tree fasteners or their tree-lok fasteners as an alternative primary fastening system.
Bob, you have it correct on what I am doing.
I have thought of doing the screwing from the back on the 3 drawer unit I am installing under the bunk. The two unit under the dinnet is more difficult to get to the back. Only a small opening in the seat bottom.
My other concern is that the trim material in only 13/32" thick. I would have to use short screws and be very careful. These pieces were made by resawing 1" boards down the middle.
I have now put teak oil on some pieces. So far very pleased with the look as compared to the teak that is already in the boat.
Thanks for all of the inputs.
g
