You won't get the full potential out of the AGM battery(s). They like to float higher than lead-acid. They also like, but don't need, a much higher charging amperage (with a high-power charger you can bring and AGM up faster than a lead-acid).
Also note that while again you're not going to increase your bank capacity with the same-sized AGM vs. lead-acid (they'll both have similar power/amp hours if the same size), you may run into an issue with your house battery if you switch to AGM and you don't fully charge it each time it's discharged. Look up cruising forums and see how many cruisers have switched to either Gel or back to L-A. Over time crud builds up on the plates, especially if at anchor and not bringing the bank fully back up (tough to do). L-A batteries can be equalized to compensate for this issue; AGM batteries (other than Lifelines) cannot. I fell into the "AGM batteries are better" trap about 2 years ago. At 18 months the AGM batteries were shot and I went back to L-A. Thankfully, the pro-rated warranty more than covered the switch.
