Originally posted by KiDa
Ron,
I've no experience with Flagship so I'll defer to Hogan on that one. I like the concept though.
My only concern would be the added load on the gennie while underway in colder weather. It may present a new load management situation or one that is insurmountable with your current Gennie.
Just something to consider.
My 2 cents.
Originally posted by rbmitchell
Getting seawater (raw water) into the refrigerant should be all but impossible. The Dometic units (Cruisair or Marineair) use heat exchanger consisting of two concentric tubes. The refrigerant runs on the inside and the raw water runs outside of the inner tube and inside the outer tube. Since the inner tube is the only refrigerant/raw water interface, a perforation would have to exist in the inner tube. The refrigerant pressure is much higher than anything expected in the raw water, the leak would be of refrigerant into the raw water. Not vice versa. If there was something to cause the perforation, your unit would have crapped out well before you found water in the refrigerant.
Originally posted by bobalong
My current 93 Crusair blower runs non stop in the heat mode (and A/C), even when the desired temp has been reached. Consequently I run the fore ward unit when we are sleeping aft. That non stop dry air is uncomfortable.(this ain't humid coastal real estate).
I've looked at all the info I can find on circa 93 Crusair thermostats and can't find any adjustment for this condition.
Is the thermostat "new" enough to be a "Passport" controller? The blower can be programmed on those...
-Chris
-Chris
Don't have the manual here at home but seems like there were some adjustments that could be made by holding one button and then pressing another to effect the change. Not even sure I have the exact manual since I had to match a picture of the thermostat to something on the internet.
Ron,
My 2 cents.
No genset. Electricity use is not a concern as long as it and other appliances (water heater) together don't trip the breaker.
Examining the warranty, it is my opinion that I still have a month left on the "parts only" portion. If the AC guy doesn't respond to my email I will contact Cruise Air.
As for them offering resistance heat, we're talking about the small self contained units here. If Cruise Air and the dealer won't stand behind their product, the replacement won't be a Dometic unit.
Ron,
My 2 cents.
My water heater and AC are separate and on different legs. Is that a possibility?
Originally posted by waveform
I believe that Ocean Breeze and Flagship are the same. They are located in the same building anyway, and look pretty much the same.
I have had good luck with the Ocean Breeze. They are in Stuart, Florida
Save the heat exchanger. It is easy to test it for a leak. You simply pressurize the water side with air with a pressure gauge on a tee and watch the decay, if any, of air pressure. This is a standard "leak down" test. If a leak is found, shown by a loss of pressure, the heat exchanger should be opened up and examined for the cause. I would expect a defect in material or workmanship. If there was (is) some sort of galvanic problem, the end of the copper water tube (the inner tube) will be badly corroded before the current reaches the part by the refrigerant.
