MJ Aviator
- Jun 13, 2009
- 31353
- 7
1988 Chaparral 22' Cuddy w/OMC outdrive and 5.7 Mercrusier engine with 80 hours on it.
Coming off plane in 25-30 feet of water in our man-made lake heading into a cove we frequent all the time. At about 15-20 mph (sorry had GPS on MPH not Knots) we hit a submerged object and the boat bucked pretty good. Raise the outdrive, no apparent damage, prop intact, no apparent water coming in. Motor around at idle for 5 minutes, then head at cruise speed another 2 miles to our anchor spot. Everything operated/sounded normal. We got lucky. Not.
Get anchor set and Son says, “Dad, water in the bilge, pretty high!" The water has filled the bilge/engine compartment and the pump obviously is not keeping up. Now in 75 feet of water. If we sink, it's a total loss. High-tail it to the ramp and get the boat onto the trailer in record time.
Water is pouring out the area where the outdrive meets the transom. Hmm. Seems the outdrive was knocked hard enough that the opening between the outdrive mounting plate and the transom had water draining out pretty heavily.
My mechanic w/25 years experience said he's never seen anything like this and, “..it doesn't look good…".
The shop hasn't begun pulling anything apart yet, but I am interested in thoughts on the repair likelihood – I would think the outdrive mount can be re-seated and worst case, new holes drilled for mounting bolts if they pulled through the transom a little it.
