Hello everyone.
Just wondering how hard is it to replace the gears in the upper unit.
After removing the top cover I could see a lock nut on the horizotal shaft. When I remove this lock nut will I be able to slide that gear out of the shaft? When this gear is out of the way, will I be able to lift the gear on the vertical shaft out to replace them?
Thanks in advance.
Thanks in advance.
