Might sound like a dumb question but what keeps the drive oil from leaking when you pull the outdrives. Took them both off this weekend and can't figure it out. They are mounted to 2007 5.0 mercs with the oil tank on the motors.
Al
actually there is a check valve there too...the one on the bell housing pushes in on the one on the upper drive when it's installed. The one on the bell housing is a "male" valve, and the drive has a "female" valve.
