Alpha Drives
ALKA2710
Took the drives off yesterday for the winter and brought them home. Today opened them up to change the impeller. Now I have a strange thought. Can I leave the units seperated for the winter with no oil in them. I think it would be a lot easier to put the drives back on the boat in half. They are so easy to carry this way. I am concerned that being there is no oil in the drive it could lead too a problem. Is this viable or not worth the trouble. I have a neighbor who takes the lower unit off is twin yamaha . Thanks
Al
Should not be a problem to leave them separated all winter. If you are concerned with corrosion you might want to plug the oil passages where the two halves meet. This should keep any moisture from getting to the internal parts over the winter.
Putting it back on two pieces makes it an easy one-person job without any special tools. The only hard part is getting the drive shaft to line up when you reinstall the upper half.
Kind of thought that it would be a lot easier to put on that way. i keep them inside in the basement so I am not to concerned about moisture. Al
