So I pretty well wrapped this job up yesterday. For a review, here is what I did over 3 Saturdays.
List of repairs done:
-Replace raw water pump impeller
-Check/adjust engine alignment
-Check gimbal bearing
-Install new transom tilt switch
-Replace trim limit/sender swtiches
-Replace u-joint, exhaust and shift cable bellows
-Replace shift cable
Day1:
-Pulled outdrive
-Replaced water pump
-Repainted lower half of outdrive
-Inspected gimbal bearing / checked engine alignment
-Installed transom tilt switch
Day2:
Dis-assembled everything - removed bellhousing, old bellows, shift cable.
Cleaned up bell housing.
Day3:
-Installed new trim sensors
-Installed new u-joint bellows
-Installed new exhaust tube
-Installed new shift cable / bellows
-Installed new water hose
-Installed new gear lube hose
-Installed gear lube transom fitting (broken during disassembly
Total cost, including the special tools I needed $413.
Special tools:
Hinge pin removal tool
Shift cable socket tool
Bellows retainer ring install tool
Alignment tool
- Total cost $100.36
I used Sierra parts, really went back on forth on this, it wasn't about cost (there is about $100 difference), it was just I can't see paying more for the same thing. I was able to physically compare the Sierra / OEM parts side by side and I just could not see any difference.
The two parts that prompted this repair where the shift cable bellows (leaking) and the trim limit switch (could not trim up) - the u-joint and exhaust bellows still looked to be in decent shape.
This is a hard job! Not technically, but physically. Things are very hard to access, stuck together, heavy and dirty. I did all of the work alone except the shift cable - I had help feeding it through the transom. It is about impossible to get it fed around the Y-pipe without a helper.
Some final thoughts:
-You cannot do this job without the tools I listed above - you will drive yourself nuts and probably damage your new parts.
-Get a good flexible shaft screw driver and every conceivable swivel socket combination you can think of for the clamps, you will need them.
-Take pictures of everything, you won't remember things when you go to re-assemble.
-I went with an exhaust tube this time. I hear it will make the engine sound a little louder, but is was easy to install and saved $ on the special tool
-Be careful removing the oil line and water hose when removing the bell housing - just cut them and replace with new. If not you risk breaking the plastic fittings that pass these through the transom. Depending on the boat you could have a real problem replacing a $15part due to the tight access behind the engine. I broke my oil fitting - took another 3hrs of removing stuff to get it replaced - on most boats the oil cooler and steering has to come loose to access it. I real PIA.
So in the end, I'm tired and a little banged up, but my wallet still has the $1000 labor in it and I feel a pretty good sense of accomplishment. I am not looking forward to doing this job again anytime soon.
Last remaining item is fine tuning the shift cable adjustment next weekend with the boat in the water.
