alpha one outdrive is leaking gear lube from the water drain hole near bottom of outdrive. Where is it coming from? I replaced the drive yoke seal in the driveshaft housing already because the bellows was getting oil in it. Now I have another leak. Any suggestions???
thanks in advance.
thanks in advance.
