There was a good article on alternative energy sources in Sunday's San Francisco Chronicle. If you are busy working on your boat or out enjoying your boat you can download and listen to the podcast.
http://www.sfgate.com/cgi-bin/article.cgi?f=/c/a/2008/05/11/BUD010IHPC.DTL
I think ethanol from non food based sources is part of the solution for alternative fuels. I look forward to buying an outboard designed to run on ethanol not E85 ethanol made from corn and blended with gas but ethanol made from cellulosic biofuels. An ethanol outboard should have more power for less weight.
I have been comming back up to speed on solar thermal since working on Solar Two 10 years ago. Solar Two had the mirrors in a circular array on the ground with an elevated boiler in the center. This required each mirror to rotate along 2 axis to follow the sun.
A boater must have come along and while looking at a lighthouse which uses fresnel lens to scatter light realizes put a fresnel lens in the light path and the mirror only needs to rotate in 1 axis, less complexity and less maintenance.
There is a good presentation on today's solar thermal capability at the following URL.
http://ausra.com/pdfs/SolarPACESMills-Morgan.pdf
Today is Bike to work day here in Leftville, enjoy. I have been riding my bike to BART now for 2 years; it changed my life and I am healthier.
