Alternator Question
fizerocks
This is going to come across as a really stupid question. We just moved up to twins (5.0 Volvo's) and I know that my port motor has my power steering pump. The startboard has the pump but is not operationally. Would this be the same with the alternator?
There are no stupid questions.
In a twin setup there will be two starting batteries, one for each engine and the alternator on each engine will charge it's respective battery.
Good luck
Niles
Good luck
Niles
Not necessarily.
You need to either document, or have your system documented as to what is there. Electrical systems are often customized to the individual boat, so even getting a schematic from the builder often is not enough.
On a twin setup, you can have one or more starting batteries, one or more house batteries etc.. Often one alternator will charge the starting batteries, one will charge the house batteries. This is fairly typical again but only because it is the cheapest way to achieve some modicum of separation of systems.
Sounds like my first project for spring is going to be drawing up my own schematic of my setup.
"drawing up my own schematic of my setup"
This is always an excellent idea. It increases usefulness, safety and confidence in the system. Plus, it makes maintenance so much easier.
