Anchor Alignment
airbus
I have a Danforth type anchor, and I was wondering what the best type of device to add that might help with alignment when I reel her in with the windlass.
Right now, just as the anchor gets to the roller, it turns sideways, so I have to manually align it by hand.
I've seen a few devices, but was wondering what works best.
if you don't have a swivel on the end of the chain, it may be of help to add one. just check the specifications of the swivel and make sure it is rated at the same or better strength the chain and or rode is.
Airbus,
I had the same issue on my boat. I did as Vic says and got a swivel shackle. That solved the problem. Never had another issue.
That will solve your problem.
Installed on my boat and can now bring the anchor up single handed.
Do as Vic says the highest rated that will fit, use wire to secure the pins.
Also helps in anchoring as the line and anchor don't
spin as much.
Abouttime
spin as much.
Abouttime
Thanks everyone ... I'll give it a try
Swivel is a great idea. Some anchor chutes have a bent bar with a uniform radius of curvature at the forward-most part that allows you to pull the anchor against it, setting the anchor in place. Or you could ask one of buddies to do it and if they messed up---- well you know!
