Anchor Light Question
fountain27
My new radar it taller than my anchor light. I cannot find a taller version of my current anchor light.
My current light is a Perko Combination Masthead / All-around Light.
Is there something special about the Masthead portion of this light or will a simple anchor light suffice?
Second, I perfer not to drill a big hole in my radar arch to accomodate the removal pole version, but I cannot find a light taller than 12". I need 18". Any suggestions?
i don't know what your current light looks like but most can be mounted on any kind of tube... either alum or SS. See if you can replace the tube with a longer one.
You need to keep the masthead/all around combo, unless your boat is under 12meters, then you can use an all around white.
just replace the tube and extend the wires...
Thanks.
I was also looking to upgrade to LED. The last time we anchored out the light drained one of my batteries.
I will just buy the LED version and replace the pole / wires.
Pascal, I feel I owe you at least a few beers for all of my questions you have answered.
If an anchor light drained one of your batteries overnight I would be concerned with the health of your battery. That is not to say that switching to the led is a bad idea. (Very good idea in fact.) I have been on hook for 12 hours straight with the anchor light on (Darkness, then the morning fog)and had no problems with the single battery running the anchor light, a stereo system, and about 5 hours of a 12V tv set. You might want to do a load test on that battery IMHO.
TG is right... draining a battery just with the anchor light isnt' right. are you sure the battery was charged?
if you want to switch to LED, then yes, if under 12m (39') you can replace the combo by an all around white.
I believe the requirement for visibility of your anchor lite is one mile. Make sure the LED gives you that. The tube Pascal mentioned is called a standoff and they come in various lengths.
The battery also runs the vacuum flush head and electronics.
I recently installed two golf cart batteries to handle the remaining house duties and start the port motor.
"—INLAND—
Lights and Shapes
RULE 30
Anchored Vessels and Vessels Aground
(a) A vessel at anchor shall exhibit where it can best be seen:
(i) in the fore part, an all-round white light or one ball; and
(ii) at or near the stern and at a lower level than the light
prescribed in subparagraph (i), an all-round white light.
(b) A vessel of less than 50 meters in length may exhibit an allround
white light where it can best be seen instead of the lights
prescribed in paragraph (a) of this Rule.
(c) A vessel at anchor may, and a vessel of 100 meters or more in
length shall, also use the available working or equivalent lights to
illuminate her decks."
"—INTERNATIONAL—
Lights and Shapes
RULE 30—CONTINUED
(e) A vessel of less than 7 meters in length, when at anchor, not in
or near a narrow channel, fairway or anchorage, or where other
vessels normally navigate, shall not be required to exhibit the lights
or shape prescribed in paragraphs (a) and (b) of this Rule."
"—INLAND—
Lights and Shapes
RULE 30—CONTINUED
or near a narrow channel, fairway, anchorage, or where other vessels
normally navigate, shall not be required to exhibit the lights or shape
(f) A vessel of less than 12 meters in length when aground shall not
be required to exhibit the lights or shapes prescribed in subparagraphs
(d)(i) and (ii) of this Rule.
(g) A vessel of less than 20 meters in length, when at anchor in a
special anchorage area designated by the Secretary, shall not be
required to exhibit the anchor lights and shapes required by this Rule."
actually, 23c is the relevant one here, under way:
(c) (i) A power-driven vessel of less than 12 meters in length may
in lieu of the lights prescribed in paragraph (a) of this Rule
exhibit an all-round white light and sidelights;
in other words, under 39' you can have a simple all around white when underway (and your sidelights). but over 39', you need a masthead visible thru 225 and uninterupted plus a white stern light.
anchored, it doesn't matter, it's an all around white regardless of size.
I have a light white light mounted on the front windshield (forward visability) radar arch (360) and stern light.
Here is a picture
I have a 360 degree visible white light on my arch and had a cop threaten to write me a ticket for improper lighting because of it about 4 years ago. He said the light COULDN't be visible 360 degrees and that I instead had to have a forward facing and a rear facing white light....PERIOD... I just said I didn't know that and he said okay but to get it fixed. Never saw him again. (never did anything about the lighting either)
I was glad to see Rule 30 (e) (thanks Liz) because I operate my little boat at night on the lake and I dont like haveing that white light on. It really affects my night vision.
While in the marine store I saw those mast head lights on 40" Aluminum poles.
I'd bet you could make a pretty nice mast out of Schedual 40 PVC and bend it to fit, making it any length you want, and mount the big light on top fairly easily.
"I was glad to see Rule 30 (e) (thanks Liz) because I operate my little boat at night on the lake and I dont like haveing that white light on. It really affects my night vision."
I'm too chicken to anchor out without lights, anywhere! maybe it's because there are too many idiots and drunks on the water around here... When anchored, night vision is too critical. On my tender, the all around is on a 4' pole, mounted near the transom, it doesn't affect my night vision, anchored or underway.
My boat came with a combo 225*/360* light. When I use the "Nav lights" switch, the 225* is lit; when I switch to the "Anchor light" switch, both are lit to create 360* light. The light is well above my canvas so it does not shed light into the helm area, but the reflection off of my white boat can be problematic at times. If needed, I will occasionally turn off the nav lights to get a visual of the area, then turn them back on. I always run at idle speed at night.
Fountain:
I couldn't find a masthead light on a pole the length I wanted, so I made one. I ordered a masthead light on the shortest pole I could find, which was around 3" or so. The O.D. on that pole was 3/4". I also bought a piece of stainless steel tubing like what is used for bowrails. The stainless tube was 7/8" O.D. and 3/4" I.D. I cut the stainless tube to the length I wanted and inserted the masthead light tube into one end of the stainless tube. Before installing the setup I soldered on wires to extend the ones that came with the masthead light. I bought a flange used for bowrail stanchions to mount the light pole to the boat.
FWIW
Eric
IMO the "combo" light is something the stylists came up with; it's pretty, expensive, difficult to maintain, and often requires a special switch. I use a separate anchor light and masthead light. The anchor light is mounted a few inches above the masthead light and the stern light is (of course) on the stern. On the little boat the dual-purpose all round light is mounted above the bimini so it's glare free.
Tanqeray you were right; the all-round light is legal up to 12m as mentioned before. The masthead and sternlight combination IS required on larger vessels but is ALSO legal on smaller boats. I've used it on boats as small as 14' because the glare is usually less.
