Anchor Line Question
Chriznat20
I have a 99 Four Winns Vista 258 (25'4") with the original anchor rode, its quite dry rot and looks like all heck.
I cannot recall what size (1/2", 1", etc..) is currently in the anchor locker but was wondering what is recommended and how many feet I should buy?
I use 1/2" for my anchor line on a similar sized boat to yours. As to how much, it depends on how deep the water is that you boat and anchor in. I have 300' which lets me anchor with roughly a 10:1 scope in 30' of water, which is about the deepest that I will ever encounter in my area.
In practice, I have never used more than 150' of line but the extra did not cost that much more and it give me a nice safety margin.
I anchor in 8-15' feet of water 99% of the time and use 150 feet of 1/2" three-stranded nylon anchor line with 30' of chain. No anchor windlass.
I like the Samson Pro-Set line I'm using right now. Nice best-bang-for-your-buck anchor line. If you use a newer windlass or want to try out the latest and greatest (and most expensive) line: look into the 8-plait anchor lines made by several rope manufacturers. 8-plait is average in strength but very good in stowage, flexibility and stretch.
1/2" shoudl be fine, how long depends on how deep your waters are... 200' is a good start but if you boat in deeper water and may need to anchor in 50 or more, then 300'+ may be wise.
I had 300' of 1/2 with 30' chain and 14lb Lewmar plow on a similar sized boat and it work great and it got tested once in extreme conditions and held fine.
Niles
Seems like your getting good suggestions above .just want to add a common overlooked thought on the last part of your question "how many ft. should I buy ".
Consider your line a emergency brake at sea also. If not your primary possibly secondary rode length deep enough to keep you put , should a problem happen where current or wind drift could push you tward danger, at times when you cruise, not only at anchor, its a good idea to have enough scope to hold you if you have to wait for help or make repairs.
Im not suggesting you carry 2000ft. with you , just reminding you to have ENOUGH SCOPE to hold you around MOST of your favorite stomping grounds in case of emergency , besides just shallower anchorages.
Safe boating , jon
Thanks for the tip Jon, and everybody else. I mainly anchor in water ranging from 2'-15' deep. I think to be safe Im going with 250 feet. And 1/2 inch seems to be the consensus! Thanks guys.
Glad I could be of some help, 250ft. seem like a good choice - best wishes,jon
One more thought on an Anchor line.
I used one of my old Halibut Ground lines for an Anchor line.
It's only 3/8" or 7/16" and stronger than 3/4" nylon braid. I dont know what the stuff is made of.
It resists abrasion, rot and stretch. Holds a knot really well too. When I was working I spliced everything though.
Being thinner than those large braids the tide movement does not affect the boat so much and sometimes it makes a differnce in how much line you must let out.
It's lighter and takes up less room and not quite so willing to tangle as some of those really fine looking fancy braided lines.
You'd have to get that stuff from a Fishing supply house somewhere.
I'm not sure if you have a windlass or not, if so check to make sure the rode will work! I don't have any experience with a windlass but I've read a lot where different lines won't work due to the size or something odd about what the windlass needs to pull the rope up and drop it in the anchor locker. The joint between the chain and rode can cause problems too. Just a thought!
Chris, you know about the 'Ring n' float' method of retrieving an anchor line? Right?
If you dont have a windlass (and if you have plenty of room in the waters around you) you can use that method to get the Anchor, rode n' all right up to a float and then just pick up all the loose line between the boat and the float.
Since it hasn't yet been mentioned - it's a good idea to have a boat length of chain between the anchor and the line - it really helps to get a strong grip on the bottom.
