Anchor Locker
dug50
I have a 2002 374 Voyager. Does anyone have any idea if there is access to the anchor locker and if there is, where is it?
there's a panel on the forward bulkhead in the master stateroom...remove this panel (velcro or lift from the bottom) and you'll expose the anchor locker door.
There is a mirror on the forward bulkhead that appears to be glued on. Do you know exactly where the access is?
Let me do some research...they won't make it non accessible
ram - as long as you're doing some carver research, would you mind looking something up for me too? i've got a 1996 320 voyager. it's not the aft cabin model. it's the one with v-drives and a large open cockpit in back. the vin is CDRM2024H596. i have a few projects for which i'll need to run some cabling from the lower helm to the upper helm, but it's not obvious how cables are run from one helm to the other. for instance, there isn't any conduit of any kind that's visible. i haven't taken the lower helm apart yet and when i do, i'll probably figure it out, but it would be nice to know in advance. below is a picture of the lower helm. any idea how the cables are routed between the two helms? thanks.
Thanks Ram. I appreciate you taking the time to research. My research has not been succesful so far. I've tugged on the mirror at the head of the bed but it sure seems glued on. I've also looked at the bulkhead through the AC access under the bed and did not see a hatch. I have to believe there is an access panel but it sure has escaped me so far.
