Anchor question
stmbtwle
Was thinking of replacing my Danforth with a Lewmar "Claw" anchor. Does anyone have experience with them? How do they compare pound for pound to the Danforth, or the more expensive Delta? Thanx.
If the Lewmar claw is anything like the Bruce, you will wonder why you waited so long to get a great anchor.
Looks like a carbon copy of the Bruce. I have a 22# Danforth now, figured a 33# Claw. It'll stow easier and the price is right.
How about the Fortress anchors. Has anyone used them, and are they worth the money?
Had a 35 Lb Delta we used as our main anchor till it pulled out one night when we were anchored out up in Cumberland Island Georgia a few years ago. Replaced it with a 60 lb Lewmar claw.
It's done super, but there are times a Danforth/Fortress is better. We now have a Fortess FX-55 that we have on the second line. And use it more often than the claw.
And is a lot easier on the windlass to pull up.
Fortress holds exactly like a Danforth 4 times as heavy. Way cooler, easier on the back. And they never ever get rusty. And if I ever get stupid again and hold the shank too low, I won't have scars nearly a decade later on 4 out of 5 knuckles. Learn from that one - a Danforth or Fortress will ruin your day if the flukes swing and catch your fingers between them and the shank. And everyone will laugh at you and hurt you as a person.
If you want an anchor that set first time every time, one that you don't have to worry about pulling free when the wind and tide cahnges, one that stays put when others are dragging, one that sets in all bottom condition, one that you can have confidance in when away from the boat on long walks, one that lets you sleep through the night then consider a "Super Max". The number one best thing I ever bought for the boat. Don't leave port with it.
I've had a few types of anchors the past 40+ years and as posted before, why I did not have a Bruce claw type before now is beyond me. Just make sure you don't set it like a danforth... IE lay it down and let it set itself without you going into reverse. Chain length also plays a part in this. I won't discuss how much cause that will only change the subject of this thread...
Hi there from New Zealand!!
A very good all-purpose anchor is what we call the 'SARCA'. You should be able to get this in your country. It is a specifically designed anchor where you go forward, then backward, and it releases it with no probs.
Stevo
New Zealand
Fav1
i have an Fx55 and love it. I the past 4+ years, it has never failed to set on the first attempt... well, maybe once.
the only down side is taht like all danforth it will not get in grass very well adn it might not reset on a drastic windshift if it gets clogged my mud or grass.
a couple of weeks ago, I was running a friends 58 and we anchored out in the bay after the fireworks in the same spot where i have anchored 100+ times. the first two attempt with the 88 delta failed miserably. the thing just woudn't hold. the 3rd time we moved 200 yards and it held. I was using all chain and up to 8:1 ! I was thinking about getting a delta as a back up, forget it. I think the mud was lighter and the delta simply couldn't hold like the FX in these conditions.
that said, i know many people are happy with their delta. While there are some limitations to all designs, anchors are still very much a matter of personal preferences but my experience with the FX and all chain has been excellent with almost 100% set and holding.
Count me in for the Fortress Anchors as well. I have an FX-11 and have no problems with it. the chain lead rode is heavier than the anchor and the anchor holds fast every time.
I had the differences of the Danforth/Fortress vs the Claw/Bruce dramatically demonstrated to me one night many years ago.
I was rafted with a similar sized boat overnight. He had a Bruce. I had a Fortress. Both were set in the sand/mud/grass bottom for the wind direction at the time.
Overnight we had a windshift. The boats spun around. Naturally both pulled their anchors out. What was found the next morning was that the Fortress had pulled, a big glob of mud/grass/sand stuck in it, & was just laying on the bottom like so much dead weight. USELESS!
The Bruce had pulled, spun, slid across the bottom a couple feet, then dug in & reset itself, this time holding both boats. All the while we slept completely unaware of what was going on till the next morning.
I still have that Fortress. It is a great 'lunch hook'. Fantastic in clean sand, useless in grass, worthless on hard bottom (as all are), wonderfull on the back if you don't have a windlass.
yep, this is the only problem with the FX, or any danforth.
it's definitely something to keep in mind if you anchor in tidal areas or in places where you will get some strong shifts. In my experience, with all chain and ligther winds, up to 10 kts, the chain will loop on the bottom and hold the boat, at least in shallow water so the anchor will not pull. ANything over 15, especailly if fiarly sudden, yes... big issue.
like everything on the water it's a trade off. but the holding power in some bottom is unmatched.
I would second the comment about the Fortress and hard bottom. I would also attribute is to the lack of sheer weight on the flukes where a standard danforth would have an advantage. The lower weight of the Fortress is a nice feature, but also disadvantage in some instances. At least that's been my personal experience.
Would have considered a Fortress years ago, but now that I have a windlass, I don't care. IMO the more weight I can get down there the better. I've had problems with Danforth types in grass, figured the Bruce/claw might be better for that. No moving parts is nice, too.
