Anchor Release?
EddieO
Hi everyone,
A friend of mine had the following statement/question, any suggestions and or info would be appreciated:
I have a Bruce anchor and would like to start tying the chain to the front and have a chain break away off the handle if it gets stuck. When I was on another friend's boat a few years back I thought I saw a wire around the handle through the chain of the anchor to break away if it gets stuck? If you know what size wire with how many wraps around please let me know. I would like to use a small rope instead of wire so I don't need tools. Do you know what lbs. test rope I should use for the break away?
Thanks much!
is he talking about the end of an all chain rode ?
if so, the best thing to do is to have about 6 or 10' of line between the end of the chain and the anchor locker tie up. or if the locker doesn't have anything to tie it, a big knot that won't go the thru the deck.
the line serves two purposes... it allows you to quickly cut free in an emergency (but tie a float first so you can retrieve it later) and it also protects the windlass since the line will normally not be grabbed by a chain capstan
I'd use a line heavy enough to hold the boat... you don't want it to break, you wnat to be able to cut it.
I believe that he is talking about attatching the chain to the crown of the anchor, and then mousing the chain to the shackle at the end of the shank where the chain is normally attatched. If the anchor is stuck under a rock, you reverse the pull on the anchor by 180 degrees, and break the line/wire at the shackle and then can free the anchor. This type of "break away" mooring has been accomplished for many years. The only problem with this, is that if the boat suddenly shifts 180 degrees, with a normal set, then this line or wire will break and the anchor will come loose.
Better to put a line directly to the crown, with a float on it, in the rare case where you have an anchor stuck under a rock or coral head. In thousands of nights of anchoring all over the world, I have never lost an anchor because it was jamed under a rock--and don't feel that the described techinique is wise.
P,
I think he wants to attach the chain the the front of the anchor and then run the chain to the end of the shank, attach wire or rope to keep it connected to the end of the shank. If the anchor gets stuck, he can break the wire or rope away from the shank by pulling up on it directly and the chain will now pull the anchor out from the front of plow portion of the anchor.
Is that what you mean Eddie?
Jonathan
Bob,
Last year fishing, I anchored in a rocky area. All chain. Delta got stock in rocks, had to swing the boat 180 and literally rip it out from the rocks. Bent the shank almost 90 degrees but managed to get the anchor out. I was sweating that one out.
Bolt cutter now on the boat and I switched to aluminum fortress too, this way if I break it out and break it, they will send me the parts to fix free of charge.
Jonathan
Originally posted by Robyns Nest
P,
Jonathan
Thank you Jonathan, yes this is exactly what the question is. Any advice would be great!
Eddie
I have considered, but not used, the float method ( described by thataway4, above ), but I would not consider the method of running the rode past a "break-away, and down the shank to the plow end. I want my anchor fail-safe ( ie: STUCK ). In some areas near where I boat, the bottom is littered with abandoned ( and also active ) gas and oil pipes, which makes for "exciting" anchoring. I had a float and line aboard for use in such areas, but never had the opportunity...
My old primary anchor for my 21' runabout was a grapple hook style and there was no chain rode (not really necessary). I used a zip tie that I could "break away" using the strength of the boat. It was all the same rope though.
Eddie
Bob Austin's advise is sound, usually is! That's the way I would do it too, separate lien and a float.
Jonathan
i've heard of that but on small boats anchored for the day in known snag areas.
I woudn't sleep with that setup... indeed a wind shift, the tie snaps and out comes the anchor. MUCH easier and SAFER to rig a float.
I agree with Pascal - there would be a lot of difference in approach in day anchoring vs overnight or longer. No way would I go to bed (or even worse, know of an oncoming storm and having to anchor) while knowing the anchor could break loose. I want that baby stuck good and solid, even if it means loosing the complete setup when I want to leave (not happened yet, thankfully).
I once read an article about freeing a stuck anchor. There was one simple tool which might just do the trick if you're snagged to an underwater line/pipe/cable - when you're stuck, position the boat right over the anchorand tighten the rode so your anchor shank will point upwards as much as possible. Attach a small loop of chain (say 2ft) around your anchor rode and, with a line attached to the loop, let it sink all the way down to the bottom of the anchor shank. Now back off a little and let out a bunch of rode so the anchor slacks and (hopefully) lies flat again. Move forward so you're just over and past the anchor and then pull on the line with the loop on it. If all worked out well below the water, the loop should be at the head of the anchor and you should be pulling it away from the obstruction. Hope I'm explaining this well enough...
Never have had the opportunity to test the above but I do carry a 2-3 ft piece of chain on board and the stern tie line would work just fine for this purpose.
Kuredu, years ago I did that trick in 75' of water with the chop starting to really kick up. Didn't have any spare chain so used some coat hangers with dive weights tied on. Tied the rest of my original rode to a couple of fenders & threw it overboard. Then went upwind to the end of the spare rode tied to the coat hangers & yanked my anchor right up.
Al
