Anchor windlass is not dropping/pulling line
GregR
2000 Monterey 302 with a windlass, not sure of the brand. There is a stainless metal plate on top, with what looks like a plastic tooth where the line feeds in. It has chain and then line. The top circular plate fell off this weekend while I was manually turning it trying to pull in the anchor.
The first symptom a few weeks ago was it would not pull line in without my assistance pulling. Now it just drops the line, freefall, with no resistance when putting out the anchor. I tried pulling the line myself from inside the anchor box compartment while operating the windlass, no improvements. I could pull the line all the way thru from inside the anchor compartment with no resistance.
I have no idea what the 'top circular plate' could be. Hopefully, just a cover.
Most all windlasses have a clutch which loosens with time. It needs to be tightened; usually be a supplied tool, but could be a simple wrench.
I suggest you try this, but also finding the make & model; then download the manual from the mfgr's website. They may also have the replacement "top circular plate'.
Just read a reference to a Monterey 302 with a Simpson Lawrence (> Lewmar) windlass, though that does not mean yours is one.
Do you recognize any of the exact models here:
http://www.lewmar.com/node/16899
Or here?:
http://www.lewmar.com/windlasses
Didn't a manual for the windlass come with your purchase of the boat? That should include a parts diagram, or if you recognize your model in those links there should be a downloadable manual.
Thank you for the feedback. It looks like the Sprint 400 from memory.
Yes, there is a manual on the boat if I recall. I'm the 2nd owner, previous owner kept everything, which has been helpful. It was midnight when we docked, raining, 7 hour idle cruise home, too tired to look then. I'm an hour from the boat, I will check for a manual make and model this weekend.
If it is a S/L Sprint 400 , perhaps this will help, as least to visualize parts:
https://www.p2marine.com/anchoring-docking/simpson-lawrence/simpson-lawrence-sprint-400.pdf
I don't know much about windlasses, but it looks like that model doesn't have an adjustable clutch mechanism that I could see in the diagram & list.
Unfortunately Lewmar is in the UK, so phone support (Tel: +44 (0) 23 9247 1841) may be a little more complicated, but FWIW they do have a US email support address:
"US Tech Support Email: ustechsupportrb2@gr5tlewmar.com "
http://www.lewmar.com/contact
The Lewmar V700 series is reportedly the closest relative of the Sprint 400:
http://www.lewmar.com/node/11627
http://www.lewmar.com/sites/default/files/sites/default/files/V700 manual 65001022-iss8-Eng.pdf
