We have a trailed 1987 22' Grady which I discovered last week that I have significant blistering where the hull rests on the carpeted bunks. There are two strips approx 3"x10' with the blisters.
This problem, I suspect, is the result of having the bottom paint sanded off 3 years ago since bottom paint was unnecessary. The hull was clear when the paint was removed.
Reading the thread from RPM-inc leads me to think I will need to sand the areas down to the fiberglass, clean up any damaged fiberglass, let it dry then reapply gel to the damaged area.
Does this sound like the right approach?
Am I asking for additional trouble (damage) if I hold off on this repair until December?
Appreciate your suggestions.
