Another docking situation
Thompson gunr
I am looking for the best method for docking my boat.
The dock situation:
My dock space is a finger slip on the Ohio river. There are two boats in this finger slip area side by side. As I pull into my slip my starboard side is to the finger dock. The current of the river runs from starboard to port as I pull in. Of course this pulls me away from the dock towards the other boat in my slip. The slip is a single finger, meaning that there are no other fingers off my stern when I am tied up to the dock. The water fairly quickly loses depth as the shore is off my stern. There is enough depth for me to back out of the finger without running aground. It is VERY difficult to dock single handedly if not almost impossible with a strong current.
The boat:
My boat is a single engined I/O on a 25' cuddy cabin. Getting out onto the bow of the boat with any degree of speed is impossible for my old butt!
What I have been trying to do is as follows:
I pull behind the dock (into the current) and move up to the end of my slip. Right before slipping the drive into neutral I turn the wheel full port. I then slip into neutral and turn the wheel full starboard and slip it into reverse for a short moment. This starts bringing the bow around to the port into my slip. The current starts pulling the bow downriver and as soon as it looks like I would run into the end of my finger I slip the drive into forward. By the time the boat starts moving forward the bow has cleared the end of the slip and barely misses the end of the finger. As I move into the slip (still drifting down current) I turn the wheel full port to move the stern towards the dock. I quickly have to put the drive in neutral and grab the stern line off the dock and secure it to the rear cleat on the boat. I then have to run back to the helm and turn the wheel full starboard and put the drive back into forward. This pulls my rear line tight and I can actually move forward and tie the front line. Then I move back to the helm shift back into neutral and finish tying up.
As you can tell, this is a VERY difficult procedure. I DO NOT like the idea of leaving the boat in gear at low idle when leaving the helm!!!!! BUT... If I don't do that, by the time I get off the boat and get to the bow line the boat is already drifting over and playing bumper boats with my slip neighbor. Any ideas for a better way to do this? It would not be so bad if the current was pushing me into the dock instead of away from it. With two people this isn't nearly as hard. I would like to be able to do this more easily singlehandedly.
I am open to suggestions. Thank you!
Anyway to hang a line on a pole? I didn't really follow all those moves, but if you can grab a line while you are pulling in you can tie a tight line to the midship to hold it while you get out and do other lines.
i agree this seems like a great opportunity for a spring line or a midship line to hold you fast.
The slip has only two cleats. one in front and the other in the rear. I am going to be installing poles this week to support my docking lines. The lines will be held to the poles by velcro loops. I guess I could tie off to the front dock cleat and put a line to my center cleat on the boat. Good idea. While not keeping the boat tight to the dock I guess that would keep the boat from drifting too far towards my neighbor until I could get the bow line properly tied. It is really a hassle running fromnt to rear to do the stern line then get back to the helm. I just figured there would HAVE to be a better way.
If there is room, you could throw some big orange mooring balls on cinder blocks between the two boats. This way there is some dividing line protection for both boats. Depending on tides and current, this may not be feasible.
As for the lines, add a pole midway on finger with a line that goes from cleat to cleat. Put a loop in the line. As you come in grab this line and loop it onto the midship cleat. This will spring you close to dock while you do the other lines. Once they are done you can drop this line. Another options is to leave line on boat with a big loop and just loop pole as you come in.
I also had a hard time following your movements. At times I also come on and off the dock solo. I also deal with a strong current, but I dock parallel to the dock, and depending on the tide, parallel to the current, or at an angle to it. I have 3.5 feet between me and the boat in front of me as well as behind me. The current can be running at 5+ knots.
My spring lines always stay attached to the dock, set for my boat. This way I can attach the spring lines to my boat and hold it in place. I still have to hold on to the rail, to keep the boat from pulling off the dock, but it is doable. Before I approach the dock I put the bow line on, it is long enough that I can wrap it on the bimini support by the helm. I also dock the boat standing behind the helm seat, so I can get right on/off the boat.
Some suggestions for you.
Add more cleats to the dock, where you need them. IE, I cleat on the dock midway between the bow and your midship. Hang your bow line so you can grab right after you come into your slip, and drop it around that cleat, You can control the bow movement from there.
Pratice docking solo, with someone on the boat, and someone on the dock. Have them there, but they only "help" on your request, and only request if you are in trouble and have no way to recover solo. This gives you the practice you need, so when you are alone, you already are comfortable with the routine.
Hang fenders on your port side, so if you do slide down river, you do not damage your slipmates boat.
And remember, this is all just advice, and it is much easier to give from the keyboard, then it is from the helm as you are docking!!!
Talk to the Owner of the.....Marina?....and see if he he/she can assign you another dock on the upstream side.
I can understand your frustration with all that manuevering with a single. Maybe suggest to him/her that the docks downstream are more suitable for twin engine boats?.....and just tell the person that it's just to difficult to handle in the current and you don't want to risk damaging other boats.
"By the time the boat starts moving forward the bow has cleared the end of the slip and barely misses the end of the finger"
i don t' understand if you are backing into the slip or coming in bow in ??
so, you are in a double slip, with a finger on starboard and current pushing you off the finger pier and into your neighbor? correct? but are you backing in?
how wide is the slip/space between the dock on your starboard and your neighbor?
sometimes, if the conditions are too bad, you have no choice but going bow in and/or using fenders between the boats...
Karl, I feel your pain! I've been in your situation at a guest dock. Thankfully, someone on the dock came to give me a hand. While reading your post, I found I was holding my breath! I knew exactly how you felt and what you were describing. Whenever I have a choice, I will pick the up-current/wind side of the finger to tie up. You don't have that choice. Good luck!
Tanq has the best suggestion. In the absence of being able to move.....a couple of things come to mind immediately. Anything coming to my mind that fast is usually FUBAR in nature but here goes...
1)--Is there a piling between the to tie off your port side to?
2)--Is the Ohio a tidal river?
If there is a piling to tie your port side to, you could run a 1/2" or bigger braided line from the piling to the pier streched REAL tight at less than gunwale level. This could act as a barrier to allow you some wiggle room while docking. If the Ohio is tidal, you will have to run more than one line.
You may also want to consider what I call a bridle set up. It is like a modified spring line. Add two more cleats to your dock, or better yet, use the poles you are about to install to hold your lines. Brace / Attach them strongly as they will become load bearing. Place a length of braided nylon between the poles. It does not need to be too tight and you may want to make it removeable to avoid a trip hazard when not in use.
Attach a line from the bow cleat to the stern cleat starboard side. Make it loose enough that you can easily hold it while at the helm. Place a carabiner on the line between the cleats. You will need to play with this to see where the carabiner should be tied off, if at all. When you get dock side, snap the carabiner to the line on the dock. That should keep you from drifting toward your dockmate. Once you tie her up to the dock, you can remove the carabiner until you need it again or keep it on if leaving the dock is equally difficult.
Alternatively, you could fashion a "ring" of sorts made from (plywood, starboard, PVC... your choice). Attach a line to it and to your front cleat. When you are coming in, place the ring over the pole you are making for your (bow) lines. Put the boat in reverse, rudder to starboard. This will pull the boat to the dock at the stern and as the line on the bow tightens, it will come along side as well.
No Pascal, Sorry if that was confusing. I do not back in I pull in. The current is pushing on my starboard side pushing me off the finger towards my neighbor. I will try to state this clearer so it makes sense. I am traveling up river with the dock on my port the shoreline on my starboard when begining these maneuvers I spoke of above.
There WAS about 4.5 feet between my boat and the neighbor when docked but they have reassigned the slip next to me to a pontoon boat and it has a much wider beam than the old boat that was docked there. Of course this leads to more palm sweat as I am coming in. So I would guess the distance between my dock and the neighbor's boat at about 11 feet or so. I have an 8' beam on mine.
NPH, I wish I had a dock space that ran parallel with the current! That would make it MUCH easier! I used to dock the old houseboat in that situation single handedly and never even tought about it even with boats docked right in front and behind my boat.
Tangueray, I thought of that but unfortunately those spaces are first come first serve by seniority. So, being new to the dock that option is out. I have to wait until someone else gives up their spot. Maybe next year. There ARE other singles at the dock in the same type of spaces as me BUT I never have seen them leave the dock let alone come back. I always wondered why have a boat and pay for the dock space if you are not going to use it. If I ever saw them come back I could get some better ideas.
Thanks Liz! It is a nail biter!
KiDa, The Ohio is not tidal (although they do change the water level quite frequently as of late!)and there is no piling unfortunately. That would have been a GREAT idea though! I don't know about adding a cleat to the dock as the deck of the dock here is steel. I guess I could lag bolt it to the side of the dock where I am putting the poles for the dock lines. The problem then is that the cleat would be sideways. I guess I could make a permanent looped line and leave it looped through both cleats. I don't know about making those poles load bearing but I could try that. That would be quite a load pretty high up a 2X4. (Quite a bit of leverage.)
Allrighty.....Now I'm getting a better visual....
Simple solution.
When returning to your dock......go PAST it and turn around...Now you'll be coming WITH the current but that's okay.....Ease in right alongside the end of your dock and have a springline pre-attached to your starboard side.....Get alongside the end of the dock and hook the springline to a cleat that you're going to put there for that purpose...
You should be able to work the springline from the helm and get yourself in with no problem.
When single handing my boat in conditions you describe, even with twin screws, I will put a line on my midship cleat and run it back to the aft cockpit near where my stern line cleat is prior to docking. That way I can secure the stern line and step onto the dock with the spring line in hand ready to control the movement of the bow. If you can reach the midship cleat from the helm you can have the springline attached to the back cleat on the dock ready to grab and loop over the midship cleat, then the forward motion of the boat will natually pull the entire boat to the pier as the line tightens. I have found that use of that midship cleat is a big help in many docking situations.
ok so it's bow in... now i get it!
so you are approaching up river then turn to port into your slip which has the finger pier on the stbd/up current side and a boat on the port side. Current pushes you onto your neighbor, correct?
if so... first thing is to have 3 large fenders rigged so that you can "lean" on the other boat if needed. It's not very elegant but sometimes you have no choice... it's ok for boats to touch with fenders!
you need to come in at a slight angle with just enough speed so that you dont' spend a lot of time beam to the current. Obviously you dont' want to come in too fast and have to slam it hard in reverse not to hit anything but this is one of these situation where a little momentum is needed to minimize the time you are vulnerable. the key is to time the drift of your boat due to current and the angle/distance...
if the you can reach the dock cleat from the boat, you can set a spring line before coming in, from the midship cleat and leave the bitter end in the cockpit. Once you're in, you should have time to pass that line on the dock from the boat if you can reach the cleat. Then you can go back to the helm, put it in fwd which will keep you in position alongside your finger pier.
if you can't reach the dock cleat from the cockpit (too low, too high...) then you can leave a spring on the dock coming from the far end of the slip and long enough to reach your stern cleat. once you have boat along side, you can grab that line with a hook, tie it to your stern cleat. by putting the boat in reverse you will pull against the spring and stay alongside the finger while you tie the other lines.
Thanks to all for the ideas. I will experiment and let you know what worked out best. I LOVE to take the boat out so I need to figure a way to do it single handedly. You all have provided some good ideas I should have thought of myself. Sometimes you are just too close to the problem to see the easy answers. Thanks again to all.
Karl,
I used to be in the same situation. You were trying to dock when the water was high and the current was swift. Now that everything is back to normal it won't be as bad. Generally the wind blows up river and is stronger than the current.
Paul
Glad to hear that Paul! The Admiral I and I were really getting concerned. BTW, I am back from Bonaire and will be down at the boat doing some work on Saturday.
We'll be leaving the dock about 7am on Saturday for Paddlefest Patrol. We should be back around 1. Hope to meet your new bride then.
Bow in. That changes everything. You could stretch 6 lines across the slip and try to trap the number three wire with the bow cleat!!
You could still use the bridle assembly, actually this would work better.
Materials:
Drill
Drill bit (your choice of size)
Two eye bolts much longer than the wood part of the dock you are going to drill through.
Four nuts
Four fender washers
Two lock washers
"X" feet of braided line.
Drill through the wood on the side of the dock fore and aft. Use the drill of your choice of size as you know the water and current. Get one of the eye bolts much longer than the depth of the wood you just drilled. Place a nut and a washer on the eye bolt. Tighten the nut enough to allow the eye bolt to pass completely through the hole you drilled. Push the eye bolt through the hole. Place a washer, a lock washer and a nut on the other side. tighten the second nut enough to make sure it is threaded all the way through the nut. LOOSEN the first nut until the assembly is tight against the board you drilled. This should stand the eye bolt off the dock a couple of inches or more. Repeat the process for the other hole.
Take the "X" feet of line and thread it through the eye bolts. Tie it off. You need very little tension.
Use the bridle I described before, but make it out of a bungee cord. Attach it to the front and center cleat. It does not need to be tight. Run a line off the bungee cord and attach a snap link or carabiner to that line. On your way in, snag the line between the eye bolts and that will hold you near the dock while you maneuver.
I did not make myself clear about the "ring" assembly. It should be like a donut and the center hole needs to be wide enough to slip over the pole, the line holder, lines and everything else. I don't know how tall this pole is going to be. Not too tall I would guess or you couldn't reach the lines.
I'm thinking you tie the bitter end of a off the donut to the stern cleat. As you pass the pole you slip the donut over the line pole. Give yourself enough left rudder to keep the bow in and leave it in gear as you tie off the bow or snag the aforementioned line through the eye bolts.
I can picture this but the visual from my brain to the keyboard probably sucks.
