Another prop question...
brad10281
I'm sure there have been plenty of discussions on prop selection. I'm requesting a little advice here. My current prop is 13.25" x 17". WOT range for my motor is 5000-6000 rpm, currently running at 5600 rpm at WOT. My question is how can I get a little more hole shot performance? This is on a 115hp 4 stroke Mercury Outboard. Do I have any options? I realize my prop/motor combo is running right where it should be...according to what I've read. I'd appreciate any advice anyone can give.
Some folks drill a holes in their prop hub in front of the blades to make it a "ventilating prop" . The idea being when throttling up from stop, the exhaust pressure will push some exhaust gas out the holes & over the blades to cause them to temporarily ventilate and build rpms rapidly at which point the boat is moving fast enough the exhaust is all pulled out the main hub exit, ventilation stops and the boat accelerates faster than with normal prop. "Your mileage may vary."
As you point out your observed WOT is pretty good so I wouldn't change dia. or pitch. Extra cupping is likely to drop WOT .
Do you have trim tabs?
Thanks for the info...I'll do some research on ventilated props. Nope, no trim tabs here.
