Avon inflatable?
PatSea
My wife and I are wanting to buy a used inflatable to "putz" around the marinas and over to the beach. I have a chance to buy a 10' mid 80's Avon inflatable with a mid 80's 7.5 HP Johnson outboard for about $900(no trailer). I'm told the Johnson was overhauled last year and runs good. The boat has wood floors.
I'd like your comments on this. Is the Avon a good brand? What should I look for when I go to inspect it? Any other suggestions or comments.
I have owned Avon, Achilles, Zeppelin and Zodiac. I rank them in that order with the Avon being the FAR superior-and most expensive to buy; but least costly to own. I currently have a 1990 Avon.
I bought a 20 yr old Avon with a mahogany floor. and a mahogany bracket to support an OD. It was in great shape when I bought it and it is still in great shape!
Just make sure that it has no patches and closely inspect all the seams. It will be perfect for your needs!
Avon makes an outstanding inflatable. Shockingly well built. The transom, however, needs to be taken care of. I'm currently in the process of replacing the transom on one - have been in the process for a couple months, but that's mainly due to delays caused by a shoulder injury. The transom was starting to bow and had a vertical crack starting that was starting to seep water through it. Previous owner had screwed things into places where things shouldn't have been screwed. Taking the old transom off turned out to be a beast, though - Avon did NOT screw around with the way they attach those things. Took the better part of the day and a week's worth of patience to remove all of the very well glued and thought out tabs holding it in place. I hope to have the transom ready to go back in by the end of the week, which will be another tortuous process. These things just weren't designed to fail.
Thanks for all the replies. Sounds like Avon makes a good inflatable.
Mike, what protection or care is needed for the transom? I assume it is wood, so does it get painted? What other special care is needed?
Thanks.
Mine came through painted black and due to always being stored inside looks like new after 18 years.
Mine was painted blue - paint was in rough shape. I just picked the boat up a couple years ago (presented itself as one of those deals too good to pass up) - I was going to clean it up and replace the one patch, prep, prime and paint the transom and sell it after the summer, but I've really taken a liking to it.
Transom on this one, a 3.10 Rover, forget the year off the top of my head, mid to late 90's, while they were using the Leafield B-7 valves (which CAN, incidentally, be rebuilt in-situ without opening the fabric of the boat), was made of good, high grade mahogany plywood. Except for the big vertical crack from an atrocity perpetrated by it's previous owner, the wood is still in great shape, despite the paint having failed a year or two ago and it's current owner still not getting around to it. That crack was no good, though - whole transom was flexing and bowing real bad. Original owner had taken a piece of aluminum and wood screwed it to the bottom of the transom - I assume to keep the fabric from chafing, but at the expense of wrecking the transom.
Have any more details on the boat you're looking at? Year, model, valve type, pictures, number of patches, lifting seam tape, lifting floor, keel and sponsons holding pressure, sponson baffle intact (if one side is fully inflated and the other side is deflated, do both equalize? Shouldn't)
I've owned Achilles boats for close to 20 years now. You should consider them as well. Great boats, good prices, good warranty.
They are indeed. They still use Hypalon, which is superior to PVC in every single way - even cost, when you look at the disparity in reasonable service life between the two materials.
