Backfilling 5.0 LEFI - a few questions-
searayjay
Thanks all in advance -
I've read all the posts but still have a few questions
5.0L EFI Bravo III- RWC
I've located all 6 drains(2 mani, 2 block,1 hose into water pump, 1 on fuel cooler) and drained all the water.
1) with raw water pump on motor, I pulled the hose off one side of the PS cooler (comes off output of RWP and filled but how do I fill the intake side of the RW pump?
2) I'm planning to pull each manifold hose off therm housing and fill but should I fill until A/f comes out prop? Will it flow up over and out like that?
3)I'm going to pull and fill both big hoses off the therm housing (1 goes to fuel cooler, other to water pump and block) but how much will the block take? I think I put in 2 gals and not full yet- Is something wrong?
Brand new boater and I want to learn but scared to do it wrong-
Thanks-
