My port engine (Mercruiser 6.2 Horizon FWC) started to overheat today. I checked my Seawater pressure and it was fine. Checked my strainer and it was clean and water was flowing through the seacock. I opened the pressure cap on my heat exchanger and didn't see any coolant in there. Recovery tank was empty too. Looked around the bilge, didn't see any coolant anywhere. Hoses all looked good. Put a half gallon of coolant into the heat exchanger and started to engine. The temp started creeping up again.
I took off one of the end caps to see if I needed to flush the raw water side coolant poured out. So it looks like there is a leak between the raw water and fresh water passages. That surprises me. I believe it's copper so I wouldn't expect it to rot out.
Is this common? Just a matter of changing the heat exchanger which shouldn't be too hard.
