Originally posted by Double D
Originally posted by Cam
Originally posted by Radioactive
Bingo. We have a winner here.
Why 2 fuses ??
What is protecting the wire from the battery to the first and second fuses wired that way ??
edit.......the one thing correct with that drawing is the color of the wire from the battery to the fuses....being RED indicates fire.
Don,
The red wire is the 12v feed, like many other items on the boat, they all need the 12v feed to work.
So back to your question, "Why 2 fuses?
My response is why not?
Here is why I say that.
You have two feeds for two different purposes, if you use one fuse for both feeds, and one feed goes bad, you lost both feeds. In other words,the float shorts out, manual discharge is now also in the mud.
Guess what I am saying is we have two ways to dump water, if you protect both ways with one fuse and that fuse goes, you lost your redundancy, or override?
Think I now get how this was wired in my boat, will confirm, but think all comes from one power source.
