Batt. Par
Redge
Hello, I am a new member. Last fall I puchased a '79 CC Corinthian and I love it, but due to the lack of literature I could use some help figuring things out. Could someone tell me what a Batt. Par button is?
Battery Parallel maybe? Do you have two separate bettery banks feeding two separate engines or something? Parallel would be useful if one battery runs down, with batteries ganged together you get started anyway.
There are two separete battery banks, each with two batteries, one bank for house and the other for engines.
Ditto RonP; I have one on my boat. If the start batteries are weak, hold the button down while you crank the engine; it parallels in the other bank for more power.
At least that's what it's supposed to do... who knows if it's even hooked up?
Right now that's what I'm doing, trying to trace wires to figure out what is hooked up and what's not, and why are these wires cut, it's driving me nuts, but I enjoy it. Thanks for the replies, that makes sense Willie.
Redge, I feel your pain. Usually the worst thing on an older boat is all of the wiring. It might be easier to just tear it all out and replace everything with new wire. Then you would have less chance of things going wrong when you are away from the dock. If cell phone service is spotty in your area, bring along a hand held VHF so, if you lose all power, you can call for help! And be sure to have some tow insurance.
Best of luck in your new adventures!
Ronp, has hit it on the head. Near the batteries, there should be a selenoid. If you have some one hit the button when you are near it, you should hear it click. This will "combine" the batteries. It is used when your starting battery is run down, so you can still start the motor.
