That ASE quote is badly written and too dumbed down to be of any use even for an automobile. It's so off base, even the spirit of what it is trying to convey gets lost. Referring to ASE as the experts on alternators is like referring to a pot smoker as an expert in gardening.
The best thing you can do with your battery switch is to replace it with something more automated. If you run on "All", you charge both batteries, but lose the benefit of isolating starting and house loads. If you run on 1 or 2, you fail to charge one of the two banks.
The only benefit of these switches is low cost. Everything else is downside.
Here's what you want to achieve.
1.) Isolate starting and house loads so you don't drain both batteries and can't start the boat.
2.) Keep both batteries charged.
Study 1&2 and I'm sure you can come up with a good plan for using that switch to optimize the outcome. It takes a lot of discipline though and eventually it will bite you.
Get one of the blue sea switches that has a combiner built in.
