Originally posted by Monterey10
I have the same vintage boat. I bought mine for $3000. It came with a new trailer. I repaired the engine. They made two models of the Trophy, the Bayliner 2160 or 2359.(21 or 23feet) Your pictures are of the 23'er. They came with Volvo 4 cylinder I/Os or Outboards. Most had undersized engines because of the first real gas crunch. (.35cents up to .75cents a gal)(!)
I believe this model was made between 85 and 89. There's a lot of clean ones around for $3 to $8000. The one in the picture may not be worth anything without a trailer and engine. (check out the costs)
I like this vintage. They have a good lay out, are quite roomy and are a little heavier built than the 90s vintage "Eurostyle" boats.
The enclosed cabin will keep the sun and rain out, though, extends back a little further into the cockpit than I would like to see. This is a common set up for fishing boats up in Oregon, Washington and Alaska. (where it rains alot) The upper decks of this boat are fiberglass covering plywood, so check for soft spots. The owners I've talked to thought the 3 liter engine was just barely adequate. Most owners repowered to a V-6 or small V-8. If fuel mileage is an issue, the 3 liter may be just fine.
The bilges tend to drain forward on this boat. It's wide in the back and narrow up front, so the bow settles in a little more forward, causing this condition.
When I took my boat out for a test ride, I found it had a decent ride, probably due to the deep V hull. The boat was just a little more tender than those boats that have a flat bottom at the stern.
In summary, a good, inexpensive, roomy, easy to trailer, hard top fisherman.
The bad, the hard top can be restrictive for some people, any 20 yrs old marine power plant will be pretty tired. Check for soft spots on the deck and transom. Sometimes the forward hatches need to be replaced. I think the common replacement is the Bomar N2309. I didn't like the thin 1/2" wood used on the gunnels. I don't want the rod holders tearing out of them, so I replaced it with a thicker piece of wood.
