Bilge Pump Float Switch
A lot of good feedback. I really appreciate the thoughts.
Pascal - it's a good thought. I'll keep my eye on it with this new switch. The pump sits in the aft portion of a bilge well that is in the center line of the hull. The aft wall of the well is the transom. The two side walls are made by the longitundinals on either side of the center. The well is about 8 inches deep and about 14 inches in length. The float switch is attached to the bottom of the pump mounting flange in front of the pump - pivot adjacent to the pump, free end of the float near the fore end of the well, float axis aligns with the center line of the boat. When you accelerate any water in the well would move away from the switch, the opposite when slowing. There isn't much room in the well to change the geometry. If this switch starts hanging I think I'll go back to the caged version.
Charlie - neat idea. I can also see how the grease could trap and hold debris and possibly make things worse.
A noticeable difference between the Super Switch and the Rule-A-Matic are the dimensions of the float. The Super Switch float is shorter and wider. It seems to have less buoyancy than the longer Rule-A-Matic. One change that comes with these newer switches is they are mercury free. In fact, the wires don't go into the float at all. The actual electrical switch is in the side arm where the pivot attaches, so the switches are very different than the old tried and true designs.
