Depending on the weight of the boat you may be able to just lower the tongue to the ground, block up the frame as close as possible to the rear of the axles, then either use the trailer jack or preferably hydraulic jack and blocks to raise and be able to block the rear of the tongue enough to have wheels clear the ground , then block frame at rear of tongue and just in front of the axles. That's 6 blocking points, 3 each side for even support and it worked nicely for me. Make sure the support is even so as to avoid putting a rocker or hook in the hull and support of keel at the transom can be important. If cement blocks are used, make sure there is PT wood under & over and the block holes are vertical for correct strength. Very important to have the keel pitched enough to insure very good bilge drainage through the garboard drain , not just through cockpit sole scuppers.
