boat fix
river rat 1939
hello i was trying to get to the boat fix question part it says its locked catagory I got the subcription this past weekend don't know if it went through yet. doe's any body know if boat fix has pettit bak-v-spar with uv filter and pettit old salem clear sealer?
thanks steve
Hi Steve, At the top of each page is the ad for Boatfix. Click on it and it will bring up they'er catalog homepage.I had no problem searching for anything on there. I have no anchor as of yet. Good luck. Jerry
hello the 30' is restored . the 1939 is in the process of being restored the bottom, all the covering boards, engine, all interior are all out it's getting there. thanks for the link i though i tryed that.
thanks again
Steve,
You are right...the general BoatFix link did not pull it up. I posted a better link to search boatfix...try "pettit" again. (or anything)
When you have time, please post some pictures :) and tell about your boats. I would love to see the '65 (same year my wife was born :))
Stan
river rat 1939: I've purchased both of these Pettit products from BoatFix. The BoatFix prices are usually the best available. I buy the quarts. The Pettit BAK-V-SPAR varnish is prod. # PET2053-Q ($22.33) and the Pettit Old Salem Clear Sealer is prod no. PET2018Q ($18.67). Both items are on page 814 of the catalog.
http://www.boatfix.com/catalog/814.pdf
I'd also recommend using only Pettit Brushing Thinner 120 with these products and the use of a respirator with organic vapor cartridges(s) with the Pettit Clear Sealer: it contains naptha. I don't use a respirator with varnish, but the Clear Sealer is another story. If you value your sinuses, get a respirator. That stuff will get to you unless you are working outdoors in a stiff breeze. A respirator like this will cost you about $30 at the hardware store.
http://www.pettitpaint.com/catalog_browse.asp?ictNbr=63
thinks i found both . heres a few pictures
t1939/boatandtank008-1.jpg[/IMG]
heres a few of the 1939 when i bought it and now with the bottom and everything else off it.
