This is from the New York DMV website. The numbers were wrong where they were previously. Note that they must be on the BOW of the boat.
Does my boat require a registration?
The law requires you to register any boat that is motor-driven and is operated on public waterways in NYS. The boat requires a registration even if the motor is not the primary source of propulsion. If you operate the boat in NYS, you must register the boat with the DMV. After you register your boat, you receive a registration certificate that indicates the registration number assigned to your boat and a set of registration stickers.
You must paint or attach the registration number to each side of the bow of the boat. The characters must be:
block letters not less than three inches high,
a color different from the hull and easy to see,
legible from 100 ft. away during the daylight hours,
the only number on the front half of your boat.
You cannot transfer the registration number to another boat.
The registration sticker shows the month and the year that the registration expires. Attach each sticker in line with the registration numbers on each side of the hull, and three inches toward the stern of the boat.
Edited to post link:
http://www.nydmv.state.ny.us/dmvfaqs.htm#BOATS
