Also, it's important to figure out what kind of ablative paint they are using. It they go with a less expensive paint,like ACT from Interlux, the boat must be in motion for the paint to be effective i.e. the water's abrasive qualities allow the paint to slough, causing more copper to be exposed. If you use a more expensive paint, like Interlux's Micron, the paint is formulated to slough through a chemical reaction with the water (good for floating condos). Go with a different color base coat and you can always gauge when you need more paint.
