Bottom Paint Question?.....
Ocean Spray
O.K., so I have my boat in for a bottom job at Marine Max. After 3 days of being there, they have removed the bottom paint by sand blasting the bottom with a new polymer or plastic type of sandblasting.
Here is my question: After going there tonight to check the work in progress I have found this:
When they removed the bottom paint they have gone thru the gel coat, and the barrier coat to the core in some places. There are as many as 12 to 15 spots, all roughly one inch or better where they have peirced the core of the boat. My question is: How bad is this and what should I do about it?
I do know that exsposing the core can lead to blistering. I called Meridian, and they were not happy about the news. They said that they will need to patch up there mistakes before bottom painting can continue.
What do you think? Anyone else had a similar experience?
My worry is going to be water penatration and blistering down the road, well after the warranty is over.
Any advise?
BTW, Marine Max is not the company that did the actual work, they did farm out the job, not sure what the name of the company is.
While I would also be very disappointed and may have some choice words for them when I arrived and saw that done to my boat. I'm not sure blistering would be the biggest problem. I may be wrong, but my understanding is that fiberglass boats do start to blister after time, at least in northern climates where boats go though many freeze/thaw situations. My dad just had a 27' AMF surveyed and made sure to ask about the bubbles he saw on the bottom. He was asssured that this is normal and nothing to worry about.
Spray, I would think that the areas with open core or laminate will have to be repaired just as if it were a blister repair. Certainly sounds like this situation is getting worse.
Something New, blisters are definately not "normal" and could be a signal with a laminate problem right now.
Blisters may be common, but they're not normal, as in no need to worry or fix them. I'd look at each and every one and make sure they're fixed. Never take advice from someone who advises you not to be concerned with blisters. Just my opinion...
First. Tell them to cease and desist immediately.
Second. As the owner, you are going to personally inspect the entire bottom and you are going to take pictures of the entire bottom not just the problem areas.
Third. Drop a plumb line from the bow and the "V" in the stern. Put a tape measure between the two plumb lines.
Fourth. Inspect EVERY spot that has been abused. Draw a circle (square, whatever) around it with a magic marker and take the dimensions of shape.
Fifth. Drop a plumb line from the center of the shape to the ground.
Sixth. Get a second tape measure and measure the distance from the the tape measure on center to the plumb line. Take another picture of the intersecting tape and line. For ease of memory, get a small white board and write the location on it and include it in the picture. (for example Port Side, 12' aft of bow plumb, 18 inches out, 1/2 inch diameter infiltration to the core material)
Seventh. Prep a document in duplicate complete with printed pictures also in duplicate.
Eighth. Get Marine Max and Meridian to sign off on the document agreeing that the abused areas exist as a result of (negligence?) and that Hull ID# xxxxxxxx is covered 100% against blisters for the next 20 years regardless of who owns it.
Good luck with the eighth one.
Spray, help me understand something, you say your boat is “in for a bottom job” what does that mean? Do you have blisters? Are you just getting the bottom painted, if so why strip the old paint on a one year old boat. We need more info to advise you. When sand blasting a bottom it is common to “pierce” the gel coat and then have to fill and flair before putting on a barrier coat, but your post says they went through the barrier coat (already barrier coated), then through the gel and into the core. What happen to the fiberglass mat? Is your boat bottom cored and if so are they really into the core? Good luck on this one, Jerry
Spray,
I'm confused also...
If you had existing bottom paint, you just have to "lightly sand", prime and recoat with a good bottom paint.
Ok, now onto your situation-I would get a written warranty for next 10 years at least-they need to fix the holes and apply a good bottom paint. I would check with your original dealer to have them help you on this.
TJ
This is a common problem. I had a boat blasted with walnut shells 15 years ago and the voids in the layup are exposed. These were fared with compound and then a vc tar barrier coat was applied. I was told in advance that this would happen and what the fix would be. After the tar dried, vc offshore bottom paint was applied. The boat looked great and is still going strong. I'm not sure you can blast a bottom without some of these voids showing up, but soda is probably easier to use than other products. This is a job best left to experts.
But why the h!&& did they sandblast it to begin with. I had my new boat barrier coated and bottom painted and it is still doing fine after 15 yrs. I didn't redo the bottom paint because I put it on an air dock instead. TJ has it right.
They blasted to get the rest of the poorly applied, falling off, bottom paint off!
All the areas where the gelcoat was blasted through will need to be filled with thickened epoxy and faired smooth. After that they will need to apply barrier coat (5 coats) to get a 12 mil dry thickness. Then they can reapply bottom paint. Repairing it this way will make the repaired spots less likely to blister in the future than the rest of the boat. If they do it half-a$$ed that will be a whole different story.
OK I will try to answer all questions as follows:
1) The boat is only 3 months old.
2) The bottom paint was comming off in small sections, bad bottom job from factory.
3) Meridian forced me to use Marine Max to re-do the bottom job, or I would have to pay for it.
4) Marine Max subed out the removal of the bottom paint to another company
5) The other company that did the removal of the old paint screwed up the bottom by applying too much pressure on the nossle or gun, and went through the gel coat, the coat underneath the gel coat, and finally in to the core fiberglass or whatever the material is that they built the boat with.
Now they said today that they need to fill in those places and repair them before they can paint the bottom.
Another company was called today to do that job.
Tommorow I will go there to see what they did to the bottom today.
I did take pictures of the hull, and all of the spots I found to document them. I also called Meridian to document the bottom , there response was that I have a 5 year warranty on the hull.
So now I am not sure what to make of all of this because bottom painting is new to me and I am not sure what the damage will do in a couple of years down the road.
I really want someone to asure me that my bottom job will be ok after they have gone through the gel coat and sub coats? It just does not look good to me. I will try and post some of the pictures tommorow so you can see how bad it came out.
sorry, once again, to hear about your problems... that's not a surprise, i think that this scenario was mentioend in one of your other threads.
fiberglass can be repaired with no risk of issues down the line... if they do it right. Now, this they botched the media blasting (they dont' use sand anymore, sand buils too much heat) how can you know they're not going to mess up repairing the damaged area.
i don't think your boat is cored so what you're seing the the outer glass layer. they're going to need to epoxy this then gelcoat. i'm pretty sure meridian use vinylester resin on the bottom which is blister "resistant" or should we say less prone to blistering. i'm not sure if everything is compatible with that but let's hope they know...
I woudl document every instance and pressure meridian for an extention of the hull warranty to 10 years... 20 is a little unrealistic... especially considering the other issues you've had.
i would also get a surveyor to inspect the damage and check on the repairs...
again, fiberglass is easy to repair, but it has to be done right. frustrating situation but not the end of the world.
Should be done the way Ken said. If it's done right, you shouldn't have any problems in the future.
Pascal hit the nail on the head. Hire a surveyor to act as your advocate. Let him inspect the bottom and document by photos and with a written report, its now condition. Let him offer his professional advise as to what steps should be taken and let him orchestrate the completion of the work with MarineMax.
PasgalG,
Took your advice. I hired a local surveyor to look at the bottom and he found a bent prop, same one as last time. So off they came and are on there way to propscan via my trunk (save time). I will see what they say about the props. So far so good, bottom is patched and primed, we took many pictures to document.
Once everything is done and we are back in the water, the surveyor will check the rest of the boat out for us and we can document any other problems. Hopefully this will move the repairs along in a more timely manner.
You could almost start another thread on bottom paint improperly applied to new boats. Mine was also blasted because the Sea Ray dealer who sold me the boat did not prepare the bottom properly prior to painting it. After 3 years of dinking around with him to do it right, I moved to a different marina for my maintenance work. Sorry to highjack the thread, but I feel better.
Thats ok, read on, you would be amazed at the posts regarding Marine Max and Sea Ray/ Meridians!
Anyway, props are ok, prop scan called me and I picked them up. problem turned out to be a miss aligned engines. The prop shatfs are not straight so they have to adjust the engines when they finish the bottom job on Teusday.
I have to wonder if your hull bottom is cored? PascalG says not, but I wonder... this could present a bigger problem down the road if not properly sealed before the bottom paint is put on. The west system is often used in this situation but it can very expensive. Did your suvryor check the hull for moisture? By the way checking engine alignment while the boat is hauled out is not the correct procedure. Should be in the water for a day or two so the bottom will take it's normal shape. You bought new, so don't let the dealer and factory give you the run around. Ask for an extended warranty on this repair. Keep your eye and camera on the job. JMO
i didn't say it was not cored... i said i dont think it is ! slight difference...
so now you have engine alignement issues... great... one more thing they screwed up... they are supposed to check alignement before delivery and in the water... mrkia is right... checking alignemtn on the hard can lead to problems.
check with your surveyor... check the cutlass bearings too, they might have worn a little faster if the shafts are out of alignement.
running with misaligned shafts can also wreck tranny bearings...
