bow rails
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
My previous boat had low profile bow rails, about an inch or so above the top of the gunnel (is it still called a "gunnel" on the bow?). The Larson does not have them but I would like to add them.
I have no access to the underside of the gunnel, unless I remove a seat cushion and cut an access hole.
Does anyone have any suggestions on mounting bow rails without access underneath, and where can I purchase rails and mounts?
Here's the old boat and the rails I'd like to copy:
Here's a picture of the bow of the Larson:
Bob, you're back! Now use that anchor and get into the NBR!
Bob, there are numerous "inserts" you COULD use for mounting bow rails, but, IMHO, none would be as strong or durable as through bolts with backing plates. Suggest you give it up unless you can gain access.
I guess I can cut an access hole behind the bow seat back rest cushions, but then what would I need to do to seal them back up, or would it be OK to just leave the holes there and re-install the cushions? I don't really want to get involved in fiberglass/gelcoat repair.
Shouldn't do it unless you can thru bolt with backing plates. Could be a real safety issue if you don't. Somebody grabs the rail in an emergency and with nothing holding it fast, over they go with the rail.
I think if its not done 100% correctly, I.e. thru bolted with a backing plate. It could create a false sense of security. Especially pounding those 4-6’s crossing Block Island sound.
Or...the California Delta.
I guess you're right, the proper thing to do would be to thru bolt them with backing plates. Liz's idea on the water tight covers is a good idea, but I'm wondering if they stick out too much when I re-install the seat cushions.
P.S. Not going to do Block Island this year, but is it OK with you all if I go to Lake Wallenpaupack?
Bob, I think you would be ok cutting an access hole behind the seatback. Once you put the seat back in place you would neverknow (trim the hole with the rubber trim you can buy). Also, have you check from behind the helm and under the windshield? I agree, if you cannot thru bolt the railing, I would not install it.
Bob, correctly installed, the backing plates would be flush with the surface.........
No, no, I'm not concerned with the backing plates, I'm concerned with the device that will cover the access holes that I would make behind the cushions. If it has a removeable cover, I'd be afraid that it wouldn't be flush, and the seat back cushion wouldn't lay flat.
No , you will all drown- your best bet is sitting in the boat in your driveway and making motor boat sounds by holding your lips together and blowing.
See the link I posted earlier. "the device that will cover the access holes" is called the backing plates or deck covers. The install flush.
drilling holes behind the cushions is one way to do it...
you can also use stainless togles, that you insert in the hole, not as good as a backing plate but it's not like you're going to lift the boat from these grab rails. Problem will be to find fittings that will work with the toggles. typically grab rails have a stud bhind the ends... you'd need separate fittings.
I read a review of a Rinker about 10 years ago that pointed out that they attached a full size bow rail with sheet metal screws and no backing plates. You could do that, Bob. Go for it.
Buzz
You know with that type of low profile bow rail I wouldn't feel bad at all of mounting it with just screws. Pre drill your holes, fill holes with marine tex or marine putty stick, use the largest (fattest) stainless steel wood screws you can and get them in before the stuff hardens. The course thread screws and some type of hardener should do it. One factor that needs to be considered is how thick is the mounting surface along this area. If its thick enough to support a good size screw you should be fine. Maybe also see if you can get a custom rail with more frequent attachment points like every 12" or 18" or so. The more the better within reason. If this was the tall type bow rail that could be accidentally leaned on in waves then I would agree backing plates would be a must. I have been told that you should never tie off to or use a bow rail for support as they are inherently weak. Hang bumpers from them, hold on to them at the dock but thats about it.
Actually, cars & trucks have bumpers; boats have fenders. :)
My boat came with a tall bow rail which was screwed into the fiberglass w/o backing plates or anything! I had to have them through bolted because if the bow rail hit a piling, the screws would pop out, tearing the gelcoat and fiberglass on the way. Next time I'll look more closely at how a bow rail is designed and installed! This one flairs out so it hits before the rubrail does. Bad design.
OK, I'm pretty well convinced that I should through bolt instead of just wood screws. Where might I find rail and fittings? The local marine store is 45 minutes away, so I'd be glad to have internet site suggestions. Does Boatfix sell this kind of stuff?
