When we were at Fishers Island, they do not have a local pump-out boat; I guess he has to come from CT or Orient Point. So we made an appointment for a specific time with the Dock Master, 5:30PM. It was a new process for them so as the Dock Master said, “we have to work out the kinks”. The PO guy took down, boat name/ model, address etc. Then he wanted an estimate on how much waste in gallons I had….. what! uhh…, did not hit the half way is all I know… Ok.. I will let you know… 8 gallons sir….. He said they are required to document that. I held back the question on his estimate of solid to liquid ratio. At other places they may note the boat name / reg # but normally pump and go.
I usually tip 10 bucks, especially if I am going to return a few times. High / Low ?
