I'd check the fridg. That would be your biggest draw. See/listen to the duty cycle. It may be running too much.
You probably burned out the regulator or diode trio if it's a delco type alt. Alt are able to output a large amount of current and the regulator keeps it down to your 63 amp rating. Take it to an alt shop and ask them to up the amps. I think it's just a matter of putting in a higher rated regulator. I upped mine to 100 amps...but I'd still get that fridge checked out.
