Prospective
- Sep 7, 2006
- 23085
- 1,343
Ok, my first time winterizing the water heater. Standard Seaward 6 gallon. I take the cold water inlet hose and the hot water outlet hose off heater and hook them together. No problem.
I pour pink in the water tank (I dont mind the smell or taste so don't get started
Turn on water pump and turn on cold water spouts. Pink comes out all faucets no problem. Turn on hot water facucents and nothing, nada, zilch. Not a peep from my water pump either. What am I doing wrong? Shouldn't I have pressure on the hot water side? Shouldn't pink be comming out the hot water side also??? I know I have pressure at the bypass because when I checked the connection I could get it to spay if I loosened it.
Any idea what I'm doing wrong?
