- Dec 14, 2002
- 10885
- 228
I just pulled my filters located just before the pumps. Lots of white calcium chips. A friend says use product called Flow Aide. Tank holds 200 gals. About $30 per gal. Drain tank, use about 3 gallons and dilute with 3 gallons of water, go for a ride and let it slosh around. Run a hose from the furthest faucet back to the tank and let it circulate for about 2 hours. Water tank is steel. Pex tubung for hot and cold feed lines. Will Flow Aide be safe on system? What other options do I have? What recommendations do you have.
Ron
Ron
