Folsom is at 84% as of this mornings news. Shasta is 74% and Trinity 71%. Oroville 64%. We have some more storms coming the next 2-10 days. The problem for folsom and lake south of sac is that there is no snow pack to replenish them so they will be right back where they started by August. The northern lakes will fair a little better and not show signs until sept/oct.
Also on the news this AM, the aquifers that feed northern CA are up about 10% since all the reports that Tribble has been posting came out.
Philbo, you are correct. The central valley feeds a lot of people. However, there is technology available to cut their water use by nearly 50%. The farmers will not spend the money. For a 1/3rd of the cost they can by the Governor and other politicians. Really, all of the municipalities could follow San Jose's lead and re-cycle waste water too. Building the plant is expensive though and nobody is willing to take money from the illegals benefits and use it to build them. Residential use making up only 8% of the water use makes it hard to really have any affect. Even if you mandated they cut their use by 50% you would only save 4% of the available water. The bottle water industry uses 5%. But jobs are tied to that, same as agriculture. Cheaper to buy a politician than move a plant. And then there is the 3% of the water that goes out into the delta (and to the ocean) to keep it brackish so certain species of frogs and fish continue to use it as habitat. Of course seen parts of the American and Sacramento rivers above Sac nearly dry at times would not be good for tourism.
There are literally hundreds of reasons why the water situation exists the way it does. But only one real solution that will make any significant difference is available and that is to stop selling it to the highest bidder.
